Problem with cmw290
I'm working on test GSM using Crio 9030 and cmw290.
my problem is that my VI work correctly with LabVIEW (0 error),
but when I call my VI in LabVIEW RT, I found a problem in "rscmwgs_configure_connection_circuit_switched", in the picture below there's the code error.
(3,887 Views)
How are you deploying your application to cRIO? Definitely it is a problem of deployment settings because some VI isn't available on cRIO target. Here you can find nice instruction how to do it:
http://www.ni.com/pdf/products/us/criodevguidesec5.pdf
Hope this can help, if not we will try to figure it out somehow.
Marcin
Think Dataflow - blog.mtapp.tech
(3,861 Views)
Actually I did my application under windows then I added it under Crio, I deployed all... So LabVIEW RT could see m'y application but I didn't build a realtime application like it's seem in thé document u gave to me.
(3,828 Views)
the problem persiste! 😞
(3,816 Views)
Accepted by Maria14
I've missed from your first post that you are using rhode & schwarz equipement.
Have you maybe tried this description?
http://cdn.rohde-schwarz.com/pws/dl_downloads/dl_application/application_notes/1ma228_instruments_la...
Go to the page 43 and follow the instructions there - it should help!
Please, let me know whether it has helped you.
Marcin
(3,811 Views)
