Put the front panel of a vi to an ftp server
Do you have your VI done yet?
If so, press 'Tools' >> 'Web Publishing Tool'
A wizard will popup and walk you through the step-by-step process.
Please try this and come back if you have any questions afterwards.
We cant help you out until we find out where you are getting stuck.
Cory K
Message 11 of 14
(473 Views)
I have done it many times but when i go to the site i want, it didn't appear the front panel or anything else.
What i do is
Tools-> options-> web server: configuration-> ip address of listener-> xxx.xxx.xxx.xxx/"name"
Is there anything else?
Message 12 of 14
(465 Views)
Hi d_nikolaos,
Did you try going to Tools»Web Publishing Tool as cork_k suggested?  There is a wizard there to step you through the entire process.
Stephen Meserve
Message 13 of 14
(429 Views)
It was the first think that i tried. But I thought that this only works in a local network.
Then I tried again but i didn't manage to do it.
Message 14 of 14
(418 Views)
