Renishaw XL80
I'm using LabVIEW 2022 for 64-bit...
Also tried some ideas you showed me but only to find it fail.
I may use the software provided by Renishaw alternatively.
Anyway, thanks a lot for your kind help!
Message 21 of 25
(267 Views)
Maybe try pointing the .dll file again:
Open the file Renishaw-XL80_Init.vi open "constructor node" and select again dll file
you may need to select "DX10AdaptorClass" from the list
save the file and try connecting to your device again
Message 22 of 25
(258 Views)
I tried but still Error: 1172 from constructor node :'(
Message 23 of 25
(249 Views)
Do you have the SDK installed?
I forgot about it myself on another computer and when trying to use my own library - the same error appeared.
Message 24 of 25
(56 Views)
Thank you for giving me the idea. That may be the reason for my failure.
I will try it.
Message 25 of 25
(41 Views)
