11-09-2015 06:02 AM
Hello Everyone,
I am working on seeing the difference in displacement between two images as pixel shift. I have attached the image below showing the shift between two picture by pixels. Marked lines shows the shift. I would to make the lines in different colour depending upon the size of length of shift as there are variation due to noise. Please suggest me what to do so that I can change these lines to different colour depending upon their length variation.
11-09-2015 07:07 AM
Assumed that you using IMAQ Overlay Line. Here you have terminal called "Color". Use it for colorizing your lines during drawing.
Andrey.
11-09-2015 07:13 AM
11-09-2015 07:44 AM
Unfortunately there is no "out of box" pimitive which will map length to the color. You have to do it yourself.
Assumed that all lines created somewhere in the cycle, so you will need to map length to color by lookup table, something like this:
Andrey.
