Reverse engineering build specifications
I am a novice who inherited an existing 32-bit LabVIEW 2017 project which includes build specifications. I copied the code to a new location, made a minor change to the vi, confirmed that the vi runs as expected, then used the copied build specifications to make a new build. The only change to the copied build specifications is a new Destination Directory. There were no errors during the build, but the resulting exe doesn't run. My new Builds > Data folder is missing some files that are present in the original Builds > Data folder, including dll's needed for the exe to run. In the original, the dll's are in a folder 'MyProject Support' that is separate from the folder containing the lvproj and vi's. I can't find 'MyProject Support' mentioned anywhere in the original build specification. Where in the build specification should it say "copy files in MyProject Support to the Builds > Data folder"?
Or should I simply copy the dll's manually into my Builds > Data folder? It's quite possible that the original author did that.
(242 Views)
See Including Supporting Files in the Same Directory as the .exe File When Building an Executable?
Control Lead | Intelline Inc
(193 Views)
