04-17-2009 12:16 PM
Hi
I'm taking pictures of a 3D Picture Control panel. This is no problem.
The code that I'm using now just takes pictures and replaces those files. In the attachment you can see what I'm having so far.
The idea is every time a click a button it takes a picture of the 3D Picture Control panel and creates a new file (BMP/JPEG). It would be nice if I could see in the filename of that picture when it was taken. So if I click that button 5 times, it creates 5 different pictures (BMP/JPEG) at 5 different moments. For example: Pic 1 17/04/2009 18:43:15, Pic 2 17/04/2009 18:43:20, Pic 3 17/04/2009 18:44:59, Pic 4 17/04/2009 18:50:02,....
Can you help me please?
Thank you.
04-17-2009 01:05 PM
04-17-2009 02:46 PM
my 2cents:
-As slashes, backslashes and colons are "tricky" to use in filenames you should get rid of them.
-A naming scheme of "(YY)YYMMDD_HHMMSS_name" results in the same sorting order for "sort by name" and "sort by creation date"...
04-18-2009 12:27 PM
Hi
I think I can manage the "date/time in filename" problem now. Thanks for that.
But I'm still having some difficulties regarding the idea about creating a new jpeg file every time I click a button and not just replacing one.
What do you suggest?
04-18-2009 03:17 PM - edited 04-18-2009 03:18 PM
Hi 9 digit number,
I would also suggest to use smercurios advice of "Format date/time string", maybe with a format like "%Y%m%d_%H%M%S_Pic.jpg"...
But: first you say "I can manage the "date/time in filename" problem" and then you still overwrite older files? How fast/often do you want to save pictures? Would a simple counter do the trick too?
04-19-2009 08:47 AM
Hi
When the values of my measurements are high I want to take a picture. It doens't have to be very fast. I just want to be able to take a picture by just clicking the button so that I don't lose time filling in the name + searching for the folder where I want to save it in. And yes I think a counter would work but I havn't got a clue how to start with that in Labview 8.6.
Thank you for the previous responses.
04-19-2009 09:15 AM
04-19-2009 04:13 PM
Hi
I'm not using a loop in the "take a picture part". I'm just using a loop to get continuous measurements from my external device.
Here is my complete code. The buttons simulate different input signals.
04-19-2009 04:37 PM
04-20-2009 06:17 AM
Hi
I can but the date/time in a string and view it in an indicator and it works just fine but when i connect it to the Write JPEG Vi, it fails.
Can somebody explain me why this code doesn't work?
