Simple question
I have one simple question.
I want to make filter which allows to pass one signal only if it's value is less or even than value of 10% of other signal. That signal are numbers (amplitudes in my case).  I used Functions>>Programming>>Comparison>>Less or equal but result of that function is boolean and I want signal to pass.
Thanks!
(2,020 Views)
Accepted by Svila
Simple answer.
Wire this boolean to a select primitive. Based on true or false, pass the original signal or something else.
Prashanth N
(2,016 Views)
