10-13-2012 01:25 PM
I need do this program, but I was try 2 hours and I can´t, I know that is easy, but I´m bored.
Please, can you help me?
The diagram block have a password, I need to create the code.
10-13-2012 08:43 PM
10-14-2012 07:38 AM
We're too bored to talk to you, or help you with your homework.
10-14-2012 08:06 AM
Awesome reply, me like!
Br,
/Roger
10-14-2012 11:10 AM
carlos55 wrote:I know that is easy, but I´m bored.
This is definitely not easy if you are new to LabVIEW programming, because it involves several advanced programming techniques.
So, as a first step, I would start by assuming that is is not easy, and try to find a complicated solution instead. Once you get a working program, you can always try to simplify later. Somebody already provided you with a working program. Now try to understand the purpose of every single function on that diagram.
I understand that english is not your first language, and maybe "bored" is not what you meant. "Bored" implies that you have nothing to do, which is clearly not the case. Typically you would say that you "got stuck" or similar.
If you got actually bored in the typcal meaning of the word, maybe programming is not your thing. Try singing, painting, dancing, or gardening, for example. 😄
10-14-2012 01:12 PM - edited 10-14-2012 01:13 PM
Ah, a password protected VI.
The man was trying to guess the PW!!!!
Here's some interesting stuff regarding the PW "protection" of VI's:
Br,
/Roger
