Someone knows how to make this?
I need do this program, but I was try 2 hours and I can´t, I know that is easy, but I´m bored.
Please, can you help me?
The diagram block have a password, I need to create the code.
(2,864 Views)
(2,830 Views)
We're too bored to talk to you, or help you with your homework.
(2,810 Views)
Awesome reply, me like! Smiley LOL
Br,
/Roger
(2,805 Views)
This is definitely not easy if you are new to LabVIEW programming, because it involves several advanced programming techniques.
So, as a first step, I would start by assuming that is is not easy, and try to find a complicated solution instead. Once you get a working program, you can always try to simplify later. Somebody already provided you with a working program. Now try to understand the purpose of every single function on that diagram.
I understand that english is not your first language, and maybe "bored" is not what you meant. "Bored" implies that you have nothing to do, which is clearly not the case. Typically you would say that you "got stuck" or similar.
If you got actually bored in the typcal meaning of the word, maybe programming is not your thing.  Try singing, painting, dancing, or gardening, for example. 😄
(2,775 Views)
Ah, a password protected VI.
The man was trying to guess the PW!!!! Smiley LOL
Here's some interesting stuff regarding the PW "protection" of VI's:
http://forums.ni.com/t5/LabVIEW/Password-Protecting-VIs-is-Security-Through-Obscurity/m-p/567800?que...
Br,
/Roger
(2,757 Views)
