Something weird with right click menus and DQMH front panel
I have something really weird going on and I cannot figure it out. When I create a dqmh module and put a chart on the FP of the module, While the module is running I cannot get the right click menu of the chart to show at all. Its also not just charts it ANY controls menu. AND it only happens on a DQMH front panel. All others panel work right.
Just dont understand it. Cant figure out why. Any Ideas?
Joe.
"NOTHING IS EVER EASY"
(415 Views)
to add even more weirdness to this. If I create a module that uses the template from MGI Singleton. Then I get the correct behavior. It is only when i create an out of the box module from DQMH. Really really weird. Never seen anything like it. I am going to reinstall DQMH and see what happens.
Joe.
(397 Views)
Accepted by Joe_H
When I create a new module and open the VI properties, the default runtime shortcut menus are disabled (in Window Appearance category).  Does enabling this fix your issue?
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(386 Views)
Wow thank you. I have been using LV for 20_+ years and never really thought about that setting at all. Glad it was simple. Thanks so much.
See old dogs can learn new tricks.
Joe.
(382 Views)
