Storing data in a .txt file (RT)
Would i implement it like that?
and how will i be able to access the folder afterwards?
Message 11 of 14
(583 Views)
The project has little to do with the file structure of the cRIO.
The cRIO is a computer, with it's own OS and file structure. The root of this file structure is not called "nick-cRIO".
Have you read that article? It's all (mostly) in there.
Message 12 of 14
(575 Views)
Thank you wiebe and crossrulz for the help,
I realised that as you said a VI running on the cRIOcan only write to the cRIO drive. This way i used the information provided on this link: http://www.ni.com/tutorial/14669/en/  to create an appropriate path to my cRIO.
After that i added the Legacy FTP Server Web Feature:https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8ahSAC&l=en-GB, and then i used FileZilla to connect to my cRIO and download the .txt files in my computer.
Message 13 of 14
(549 Views)
Great!
All that's left now is to accept your post as a solution! Simply press the "accept as solution" button.
By doing that, everyone will know the questions has been answered, and start focusing on new questions.
Message 14 of 14
(530 Views)
