Support Xnet in Veristand
I am an engineer in the automotive industry. I have a problem using veristand.
Now I want to change alive and crc auto in veristand, but with alive it consists of 4 bytes and the maximum value is 15. Currently my project only counts to 14. Do you know any way to count to 14 only?
Thanks and best regards
Sonic
Message 1 of 13
(383 Views)
You can use CAN-Frame-Protection-Custom-Device. It allows you to set a max count value on a rolling counter signal.
Control Lead | Intelline Inc
Message 2 of 13
(357 Views)
Is it support in veristand 2020?
I can not find it.
Message 3 of 13
(350 Views)
I think it only use for NI-985x. But i am using PXIe
Message 4 of 13
(336 Views)
Release ni-protection-addon-2020_1.3.0.006 supports all NI-XNET modules for VeriStand 2020
Message 5 of 13
(323 Views)
Hi  ZYOng,
  Thank you support from you.
  Could you guide me how to add this library?
 Thank and Best Regards
  Hoang Dung
Message 6 of 13
(317 Views)
Quick Start Documentation is at
C:\Users\Public\Documents\National Instruments\NI VeriStand (Year)\Custom Devices\Protection and Counter Addon\Windows\Quick Start Documentation
Message 7 of 13
(311 Views)
Hi ZYOng,
 From support from you, I already add library in veristand. But I have new issues.
 Now I use caculate CRC from Protection and Counter Addon but It seems it is not calculating correctly. I already used as image below:
 But with CRC in Xnet as imgae below, it calculated correct
 Do you know how to change CRC in Protection and Counter Addon for same XNet?
 Thank you
Message 8 of 13
(283 Views)
You would need to modify the source code.
1. Download or clone from CAN-Frame-Protection-Custom-Device
2. Install all the dependencies. If you use git, you can create a branch to checkout the submodule automatically.
3. Open Calculate Protection Value.vi
4. Add a new case to implement your custom CRC.
5. Update Protection Type.ctl type def so that the new option appears on the system explorer.
Message 9 of 13
(273 Views)
Hi ,
 When I rebuild Calculate Protection Value.vi and now how I can add new this in Protection and Counter Addon of veristand?
Thank
Message 10 of 13
(247 Views)
