09-10-2024 08:01 AM
I am an engineer in the automotive industry. I have a problem using veristand.
Now I want to change alive and crc auto in veristand, but with alive it consists of 4 bytes and the maximum value is 15. Currently my project only counts to 14. Do you know any way to count to 14 only?
Thanks and best regards
Sonic
09-10-2024 07:07 PM
You can use CAN-Frame-Protection-Custom-Device. It allows you to set a max count value on a rolling counter signal.
09-10-2024 10:02 PM
Is it support in veristand 2020?
I can not find it.
09-11-2024 03:12 AM
I think it only use for NI-985x. But i am using PXIe
09-11-2024 06:16 PM
Release ni-protection-addon-2020_1.3.0.006 supports all NI-XNET modules for VeriStand 2020
09-11-2024 08:21 PM
Hi ZYOng,
Thank you support from you.
Could you guide me how to add this library?
Thank and Best Regards
Hoang Dung
09-11-2024 08:52 PM
Quick Start Documentation is at
C:\Users\Public\Documents\National Instruments\NI VeriStand (Year)\Custom Devices\Protection and Counter Addon\Windows\Quick Start Documentation
09-14-2024 08:54 AM
Hi ZYOng,
From support from you, I already add library in veristand. But I have new issues.
Now I use caculate CRC from Protection and Counter Addon but It seems it is not calculating correctly. I already used as image below:
But with CRC in Xnet as imgae below, it calculated correct
Do you know how to change CRC in Protection and Counter Addon for same XNet?
Thank you
09-14-2024 01:10 PM
You would need to modify the source code.
1. Download or clone from CAN-Frame-Protection-Custom-Device
2. Install all the dependencies. If you use git, you can create a branch to checkout the submodule automatically.
3. Open Calculate Protection Value.vi
4. Add a new case to implement your custom CRC.
5. Update Protection Type.ctl type def so that the new option appears on the system explorer.
09-15-2024 11:17 PM
Hi ZYOng,
When I rebuild Calculate Protection Value.vi and now how I can add new this in Protection and Counter Addon of veristand?
Thank
