Thermodynamic properties of R134a VI
what exactly u are looking for ? a vi that contain the properties in it , and takes temperature as input and give the properties as output and if not found it makes interpolation to get it ? ( if saturated )
Message 11 of 15
(1,020 Views)
for my part, I am interested in as much as I can get. My calorimeter program needs to have a device that takes in pressure and puts out saturated temperature, also takes in pressure and temperature and puts out enthalpy and density to 3 decimal places. There are equations from Dow but they require itteration or something. I appreciate anything available but $15k is way too much money.
Message 12 of 15
(1,005 Views)
i think i can do something like this , but instead of the equations i've created arrays with the thermodynamic properties ( for saturated r134a ) it takes temperature , and output all the values for this temperature and added a function for interpolation if the needed temperature is not listed with a range of ( -40 to 100 C ) , i can make one from the pressure table . but again it's based on the tables not derived from the equations.
Message 13 of 15
(1,000 Views)
That sounds great.  If you can make the interpolation table importable, we could switch to 1234yf also.  How much would this cost?
Message 14 of 15
(987 Views)
i need some time to add the pressure table for saturated r134a to the VI cause now i only have the temperature table , but first i would like to know how much you are willing to pay for it to see if it's worth working on the pressure table or not .
Message 15 of 15
(980 Views)
