Timed tasks
Dear all, now in the right place
Because I started this thread in a solved thread, I will copy the messages to here
I am trying to do a similar thing.
I need to do 4 tasks in a loop of 1000ms.
I need to input cycles between each task and cycles duration each task.
For example for task 1 i need a duration of 100  cycles (gives a true value) each 1000 cycles. and the same for the other 3 tasks.
I let the first code but seems complicated.....if You can help me with simplest way...I am really thank you.
It is not clear exactly what you want to do.  Please give a better description of your tasks and timing requirements.  When you refer to cycles, do you mean iterations of the while loop?
Lynn
The task will be something that works until it is true and it will be true for a certain number of cycles (iterations loop) then waits a certain number of cycles (this will be a false value) and turns true again.
This tasks will be in time with cycles of loop iterations.
Best
CPalha
Best
CPalha
(2,586 Views)
Hello cpalha,
If you want to run a task for a certain amount loop cycle and make her sleep for another one, you can use a condition loop in the while loop.
I made you a VI which explain it.
Best regards.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(2,555 Views)
Hi Sabri
Thanks for your help, can you please send a 2010 version?
Best regards
CPalha
(2,551 Views)
Best Regards.
(2,545 Views)
Hi sabri
This is very simple example, thanks a lot.
Is any way to change the times in case boxes by a control from front panel?
Best
CPalha
(2,539 Views)
cpalha,
Yes, by using event stucture.
http://zone.ni.com/reference/en-XX/help/371361J-01/glang/event_structure/
Regards.
(2,536 Views)
Hi Sabri
Can you please make a simple example.
I am sorry for that
Best cpalha
(2,521 Views)
