Unable to see Contents in Block Diagram(Labview Version 13.0)
The block diagram alone is 22+MB! Also, the origin is reported near to start near coordinate -25700.
The front panel also seems way off-center, with toptleft at ~=15k,-15k. For example if you do a "select all", there are cutoff outlines outside the scrollable area.
If you do a "select all" on the front panel and paste it into a new VI, you get tons of terminals in one big pile.
If you do the same on the diagram, LabVIEW stops responding and the front panel gets many, many screens big ( ~10x is width and height, judging from the scrollbars). I let it at "not responding" for a while and finally LabVIEW 2019 crashed. I won't try to re-open this VI.
Message 11 of 22
(2,047 Views)
It will be interesting when you post the "before this happened" version of the VI. Then we can help you avoid getting into this situation again.
Certified LabVIEW Architect
Message 12 of 22
(2,042 Views)
Have you managed to tick the VI option to Remove block diagram? If so, i do hope you're using SCC.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 22
(2,035 Views)
I am hearing SCC term first time in this forum.Is there any link so I could know more about it.I didn't find SCC in my Lab view Project.
Message 14 of 22
(2,031 Views)
I suspected that. Here's a starting point.
But you have regular backups at least?
Message 15 of 22
(2,027 Views)
I don't have recent back up. I did lot of implementations in this file.please help me to resolve this issue with this file.
Message 16 of 22
(2,028 Views)
https://en.wikipedia.org/wiki/Source_Code_Control_System
Qestit Systems
Message 17 of 22
(2,002 Views)
Hi avana,
So it's all your fault.
Use the "not so recent" backup and start again to implement your changes, but now in a more sensible way…
Message 18 of 22
(1,975 Views)
Accepted by avana2006
The while loop on your VI hit the size limit which causes all sorts of trouble.  Easy enough to fix.
You are playing with fire with this huge BD (and the locals, and the sequences).  I'd suggest you take a deep breath, study a few LV tutorials, and then start working to shrink the code.
Message 19 of 22
(1,954 Views)
Oh, what a mess! It might be easier to start from scratch. Even bringing up the navigation windows takes 30 seconds and then the navigation image is corrupted. Diagram is sitll ~40k x 30k 😞
So. Much. Duplicate Code.
Notice that the grey area does NOT resemble the window aspect ratio at all. Even on the diagram, the top while loop does not draw correctly, here's the upper right corner for example:
Message 20 of 22
(1,940 Views)
