06-25-2009 04:46 AM
I would like upgrade labview 8.5 to 8.6. My question is, should I upgrade directly or uninstall labview 8.5 first and install labview 8.6 afterwards?
06-25-2009 06:06 AM
Hi mssm22,
you can use both versions side by side.
Mike
06-25-2009 06:50 AM
You are right. Yet my concern is, what advantage I gain of having both since am going to compile the existing VIs to 8.6 and work with 8.6. in this case would it matter what method I do to get the current labview (8.5) to (8.6) (i.e. upgrade or install)?
regards
06-25-2009 07:02 AM
Hi mssm22,
if you never again use LV85 on this pc, then you can uninstall it, before installing the new version. You can also unistall it later.
Mike
05-10-2011 12:47 PM - edited 05-10-2011 12:49 PM
hi, still i'm confused my question is there is no means where one can upgrade labview 8.5 to 8.6 without installing a new version?
regards
Pric
05-10-2011 12:59 PM
The only way to use 8.6 is to install it. It's not a 'patch' to 8.5. Once upon a time (like around 4.0), installing a new version overwrote the old. Thankfully, that no longer happens.
05-16-2011 11:13 AM
thank you all
