Upgrade reinstall labview 8.5 8.6
I would like upgrade labview 8.5 to 8.6. My question is, should I upgrade directly or uninstall labview 8.5 first and install labview 8.6 afterwards?
(3,461 Views)
Accepted by topic author mssm22
Hi mssm22,
you can use both versions side by side.
Mike
(3,452 Views)
You are right. Yet my concern is, what advantage I gain of having both since  am going to compile the existing VIs to 8.6 and work with 8.6. in this case would it matter what method I do to get the current labview (8.5) to (8.6) (i.e. upgrade or install)?
regards
(3,449 Views)
Hi mssm22,
if you never again use LV85 on this pc, then you can uninstall it, before installing the new version. You can also unistall it later.
Mike
(3,445 Views)
hi, still i'm confused my question is there is no means where one can upgrade labview 8.5 to 8.6 without installing a new version?
regards
Pric
(3,101 Views)
The only way to use 8.6 is to install it. It's not a 'patch' to 8.5. Once upon a time (like around 4.0), installing a new version overwrote the old. Thankfully, that no longer happens.
(3,096 Views)
thank you all
(3,083 Views)
