VISA: (Hex 0xBFFF001E) The specified state of the attribute is not valid, or is not supported as defined by the resource.
 It's a TI/Stellaris hardware and software.
My original post is here Stellaris Virtual Serial Port driver error in Labview
http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/p/322370/1123916.aspx#1123916
The boards not working are:
1)Tiva Launchpad http://www.ti.com/tool/ek-tm4c123gxl
2) LM4F232 USB+CAN Evaluation kit http://www.ti.com/tool/ek-lm4f232
Both of them are using Stellaris Virtual Serial Port driver.
All the symptoms are identical in mine and James's (original poster) case
Thanks for looking at this.
Jan
Message 11 of 17
(4,308 Views)
Hi Dennis,
 Did you have a chance to have a look at this issue?
Should I send you a Tiva Launchpad hardware?
or should I ask the guys from TI to do that?
We are trying to use it in a students lab, so it is imoortant for it to be resolved.
Jan
Message 12 of 17
(4,279 Views)
I would have to say no to you sending me any hardware. I really don't know why you cannot set a high baud rate. Perhaps you should open a ticket with NI. There is some incompatibility issue between the Windows driver and VISA.
Message 13 of 17
(4,274 Views)
Accepted by James1234
TI has posted a firmware update to the TIVA board. This fixes thsi issue so it now works with LabVIEW.
Follow this port:
http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/t/322370#pi239031349=2
You'll need this programmer:
http://software-dl.ti.com/tiva-c/SW-TM4C/latest/index_FDS.html
LMFlashProgrammer_1613.zip LM Flash Programmer 5924K
Message 14 of 17
(3,744 Views)
Thanks for your post...Me too facing same issue.. I have download the latest firmware for tiva board.. But still I cant set 14400 baud rate... Any more trick that works with your case?
Message 15 of 17
(2,928 Views)
Hi Sanky,
What versions of LabVIEW, NI-Serial, and NI-VISA do you have installed? Making sure you have the newest drivers that are compatible with your version of LabVIEW is a good first step to take.
Alex C.
Applications Engineering
Alex C.
Message 16 of 17
(2,906 Views)
Hi Sanky,
It was a long time ago and since then our students in a lab have no problem at all with serial communication.
Jan
Message 17 of 17
(2,899 Views)
