Watlow F4T Ethernet communication error 1172
Vi is giving .NET error while communicating to F4T controller
But. If I ping the command through NI max, giving the reply with Time out error.
(717 Views)
Hi Vikyath28
Any exception thrown when calling a .NET object property or method is converted into LabVIEW error 1172. This error means that LabVIEW received a .NET exception from the called API. The root cause of the error will be related to the .NET exception message, as 1172 is a generic error code for any .NET exception. To solve this problem, go through this article I have linked.
It will detail the necessary steps to:
  1. Obtain the full .NET exception message.
  2. Troubleshoot the error in order to resolve it.
Regards)
________
Best way to thank is to give Kudos / Mark as a solution.
(680 Views)
