Hello all,
I'm using the wizard to import two webservices into libraries.
But both of them have the same asmx name, example:
http://path1/NAME.asmx?WSDL
http://path2/NAME.asmx?WSDL
I have no control over the names and paths, being only an user.
Altough the names are the same, they have diferent functionality and work with different products
When adding both libraries into a project, opening one of the generated vis, Labview will load with the wrong dependency, poiting to the dll of the first added lbb.
I've tried renaming both dlls but had no success.
Can anything be done?
I'm using labview 2017
