What is the best way/place to initialize everyting in my VI?
Accepted by rkmadse
For myself, I tend to lean towards the JIT (Just In Time) approach. Whenever I can, I try to make modularized functions self-initializing. The "action-engine" design pattern that Ben Rayner formalized a few years back is a good model.
For state machines, I like to have a clearly defined initialization state -- even if right now it will only run once. Having it as a separate state simplifies the changes if the machine ever needs to reinitialize itself.
Knowing when and where to initialize things can sometimes be tricky -- and highly dependent upon system requirements.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 12
(1,147 Views)
@aputman wrote:
This will handle default values that have been saved to a control/indicator.
I was always a fan of initializing controls to explicit values rather than reinit to default.  What happens if the defaults are accidentally changed?
Bill
CLD
(Mid-Level minion.)
Message 12 of 12
(1,116 Views)
