What is the best way to connect PumpWorks to Labview? DDE or OPC
What is the best way to connect quizix PumpWorks to labview?
PumpWorks share data using Dynamic Data Exchange (DDE),what is the best way? To use an OPC Server betwen labveiw and pumpworks or  DDE?
(3,599 Views)
Hi.
If the instrumet can communicate with an OPC server I think both methods are fairly equal.
There is a chance that you might have to reinstall LabVIEW without OPC server if you choose DDE, as it is known that it might conflict with the DDE server.
http://zone.ni.com/devzone/cda/tut/p/id/4531
http://zone.ni.com/devzone/cda/tut/p/id/7450
-Tom
(3,582 Views)
The PumpWorks program can only use DDE communication linkl: http://www.vindum.com/Q%20PumpWorks%20Manual031306.pdf
The question is: What is the best way to connect the program with labview, use DDE or use for example Kepware OPC Server that can communicate with both systems.
Thank you for your answer!
(3,577 Views)
Accepted by A3ea
If the program only handles DDE communication the best method will be via DDE, as LabVIEW handles this. Otherwise you will have to add another instance to the system(OPC Server) that will make it more complex, and causes more overhead.
See the previous link under "Using LabVIEW as a DDE Client".
-Tom
(3,564 Views)
Thanks Tom!
(3,562 Views)
