Why do very few programmers use LabVIEW unit labels
The coincidence with the Nugget is simply that, a coincidence.  It is interesting that one comment was that someone took beginner, intermediate and advanced courses and units were not taught.  Perhaps this goes some way to explain why they do not appear to be used often, especially be instrument driver suppliers.
Message 11 of 38
(3,545 Views)
I use units quite often. Very handy when working with systems that utilize both imperial and metric units of measure.
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
Message 12 of 38
(3,517 Views)
I was in heaven when I first discovered units. Halleluja! I often want to change displays from minutes to seconds, and this makes it super-easy. But now I'm being crippled by bugs when I write subVIs that use generic units.
Message 13 of 38
(3,345 Views)
Like all functions in software.. If it is not complete (having too many bugs) It is better not to use it.
So NI, please flag all bugs with units and either solve them, or at least forbid units to be used with buggy functions.
greetings from the Netherlands
Message 14 of 38
(3,334 Views)
I've not experienced a bug wrt units.  I've never used the square function though, but this would be easy to recognise as the use of this data would not have the expected units.  What other bugs are there?  Are they fixed in versions after 7.1.
I find myself writing code for others in my company now (and here no one else uses units), and I constantly have to ask about what units their data is in!  Units everyone!
Message 15 of 38
(3,303 Views)
An other approach is to use in your software only base units, so all data are in Amps or Volt, or degrees Kelvin
And only on the user interface translate to the units people want to see.
Message 16 of 38
(3,291 Views)
My main problem with units come when I write subVIs with polymorphic units. Then I get errors like "The source is degC but the sink is $11", when my polymorphic unit is $1. The final straw was "polymorphic unit too complex" or something similar, a phrase that didn't even turn up in Google.
Formula nodes can't take inputs with units.
Maybe these things have been updated since LabVIEW 7.1, but that's what I have to use.
Message 17 of 38
(3,289 Views)
I would strongly suggest that Albert ask for working units in the LabVIEW Idea Exchange, and the rest of you kudo it.  This is a tough problem to do correctly, but it is more likely to get done if there is a demonstrable demand.
Message 18 of 38
(3,271 Views)
I'm not sure what you suggesting.  Please clarify, as I feel that this is an important topic.
Related, I recently created a company wide database and dictated that all data would be stored in SI units.  I consider this problem solved, but then I am able to tightly control the inputs and outputs: something I don't have for LabVIEW code.
Message 19 of 38
(3,253 Views)
Thanks DFGray
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Make-units-work-all-the-way-or-skip-them/idi-p/1803510
I understood and filed a very simple Idea although it is in fact a bug report.
Message 20 of 38
(3,239 Views)
