Writing LabVIEW measurements of two loops (Charge cycle and discharge cycle) in one file
Hey,
I was wondering if it is possible to write Labview measurements from two loops (Stacked Sequence Structure) into one file. Currently, it is writing the charging data in one file and discharging data in one file. I have to combine the data everytime to graph the charge and discharge cycles and sometimes there's about 50 cycles and copying and pasting does take up lot of time.
 I'll try to upload my vi in a bit
(3,018 Views)
Hi basketball,
you can use a third loop which writes your data. Use a queue to transfer your data from the two loops to the third.
Mike
(3,016 Views)
Hey Mike,
I'm very new to Labview, could you please show an example.
btw, I attached my vi and I didn't build it
Message Edited by Support on 07-15-2009 11:27 AM
(3,004 Views)
Accepted by basketball
Hi basketball,
i thought you loops run in parallel. In your case you can just use the same file path for your files. Change the option to "apend to file". After these changes both loops should write into the same file.
Mike
(3,000 Views)
Thanks a lot, it worked!
(2,997 Views)
