XLR8 and Unicode
Good morning every one.
I'm guillaume, I'm using Labview since 8 years, nice to meet you all!
Like write in the subject, I'm looking for a solution to read an xlsx file with XLR8 but in Unicode? I know how to do to that with the report generation of labview (so with the ActiveX, it's working but XLR8 is better).
Maybe there is no solution, and I should contact the developpers.
Someone has any idea?
Thank you in advance.
(305 Views)
I suspect that the strings in the spreadsheet file are UTF-8.  However I don't know what XLR8 returns.
Maybe you can make use of one of the attached files.
(265 Views)
Accepted by HVTS
Good morning,
Thanks for your reply.
I tested some file you attached in your reply. and, it's not working.
When I try to read with the XLR8 I have only "???" caracter. With the ActiveX, it was the same case but, it possible to get the refnum, and obtain a variant with the string in UTF-8 inside.
So, maybe I should ask directly to the developer. I hoped that one option was hide somewhere or getting the variant like the ActiveX solution.
Thanks a lot for your reply. 🙂
If I have any feedback from the developer, I'll reply here to share the information. 🙂
(239 Views)
