application:kind only has two options...
I want to make my executable close when I press the Quit button, so I'm following the example here...
http://forums.ni.com/t5/LabVIEW/close-window-after-execution/td-p/961740
However, when I wire up the App.Kind Property to the case structure, I'm only given the options
"invalid app kind", Default
and
 "Development System"
I haven't found anyone else who had this problem.  The documentation says there should be 6 options...
http://zone.ni.com/reference/en-XX/help/371361H-01/lvprop/app_appkind/
Am I missing something?
(3,393 Views)
Accepted by jwebster
Hi jwebster,
right-click the case structure -> create case for each item…
(3,391 Views)
jeez
thanks, I assumed it would automatically create all of them.
Cheers
(3,384 Views)
Creating a case for each automatically would make things more difficult.  Suppose you had 9 values in an enum, but wanted to group them into groups of 3.  You'd need to delete 6 of the cases one by one as you add the other enums values to the cases they have in common.
Meanwhile to go from a nice start of 2 two cases, it is just one click to create a case for each.
Also, often, I want several values to have very similar cases but with small differences.  It can be easier to duplicate a case and assign it to the new enum value, then make the minor changes to that new case.
(3,347 Views)
