cRIO 9047: Property/Invoke nodes return bad Library refnum
I'm having an issue with the cRIO and I'm not sure what I'm missing. Searching discussions and googling has not yielded an answer for me, so hopefully someone here knows what's going on.
I'm using Labview 2021 SP1 (32bit), deploying to the cRIO 9047.
I'm trying to pull a reference to a library on the cRIO 9047. The code works as expected when run on my PC, but not on the cRIO. My goal is to get the library references that are in the application. This is where I'm having an issue:
I'm filtering a list of lvlibs as expected and trying to get the owned items in the libraries. Works on the PC, but on the cRIO the `Get Ref By Qualified Name` invoke always returns a bad refnum.
In testing, I tried the following more basic test:
And here again, the library refnum is always bad. What am I missing? Is it not possible to get library refnums on the crio? Is there a setting somewhere I need change that would cause this?
I appreciate any insight as to what's going on.
Thanks.
(1,035 Views)
Usw proper error handling! All these nodes have drror input and output terminals. And I would bet one of your property nodes is not supported on LabVIEW runtime or realtime or both!
Rolf Kalbermatter
My Blog
(995 Views)
I stripped out the error nodes so I could have a minimal example. I can say that none of these blocks returns an error; I looked for that though I forgot to mention it above. It works as expected in Windows, both in development and in the run-time. I looked through the documentation and my understanding is that these nodes are supported in a real-time environment, though I will not rule out that I'm misunderstanding the documentation.
I am a little unsure about this one. The VI is in a library, but it's also the primary executable so it's possible this doesn't count as being in a library.
(971 Views)
Accepted by topic author amosbuchananoi
Followup in case someone else stumbles across this.
NI followed up with me on this: the documentation is incorrect. 'Get Ref by Qualified Name' is not supported by Labview RTOS.
(901 Views)
I'm pretty sure, proper error wire handling would have told you so already a month ago. Manuals can contain errors, and if something doesn't seem to work as documented it is usually the documentation that is wrong. So why not trying to get the runtime information first?
Rolf Kalbermatter
My Blog
(870 Views)
As previously stated, I checked error outputs and none were reported.
(848 Views)
