camera return to unknown HTTP error in Ni-Max during the IP axis camera detection.
hello,
i am facing problem regarding to connect IP axis camera with Ni-max, and I gor the error that camera return to the unknown HTTP error.
Any one please guide me how can i solve this problem.
In attachment I have attached the error screen shot pic.
thank you very much in advance.
(3,169 Views)
Hello AnkitRamani,
this may be a networking issue you are experiencing. Is the IP Camera connected to the same subnet as the PC with Vision Acquisition Software installed? Have you connected your IP Camera directly to the PC or are you using a switch or router? It may be an issue with port forwarding as NI-MAX and LabVIEW use port 8080 to communicate with an application web server. Are you able to PING the IP Camera from the PC using it's current IP address?
Did you try this troubleshooting:
http://www.ni.com/white-paper/5846/en/#toc2
Best Regards,
Cem Yalcin
(3,119 Views)
Thank you very much for your reply.
I am using router to connect the ip camera and I am able to do ping to camera.
I am dealing with Axis M1031-w camera which is mount on my Robot.
Using Axis utility I can communicate with camera on Robot but I want to use Ni-vision software but i am gettign the Error in Ni-Max.
I tried with changing the Ip of my pc for example camera's ip is 192.162.0.65 so accourding to that i change my network ip but still I am getting same problem.
and one more thing that i can also able to see the online axis camera for example just type my camera ip on web browser 192.168.0.65:8081.
It means device is connected well with pc.
thank you very much for reply again.
with greetings,
Ankit.
(3,108 Views)
Hi Ankit,
did you already followed the steps in the link which I've posted?
Kind Regards,
Cem Yalcin
(3,096 Views)
Thanks for your reply.
I have check with all the step and I didnt get that point Labview port is 8080 and it might be a issue.
could you please guide me how to solve that.
I am getting error which I have attached here in attachment during the comunication with the pc.
(3,093 Views)
please some one guide me ....
Its very important final year project..... 😞
Thank you very much.....
(3,070 Views)
I am using labview 2012.
and Max version is 5.4
Ni-IMAQdx version is 4.0
Here in attachment I have attached screen shot of available driver on my labview system.
please guide me if any update or changes I have to do.
I am getting this error.
Error -1074360277 occurred at IMAQdx Open Camera.vi
is there any suggestion how to solve this error.
(3,062 Views)
