01-23-2011 10:48 PM
I need to convert a file created using "format into file" into excel without using report generation toolkit.
Is this possible ?
Or is there any other way in which we can convert data into excel. Please explain as am new to this appl.
Thanking you in advance.
01-23-2011 11:10 PM
Excel should be able to read the filw without any conversion. Have you tried with the import options?
If you really want a native Excel file, you need to use ActiveX. Look through all of the examples on the Excel board (please don't post anything there).
01-24-2011 09:31 AM
Do you want a file that has "sheets". embedded formulas, and grahps in it or just a file that will be asociated and opend with Excell when doubble clicked on?
If you just want a file that will be opened with Excell use the write to spreadsheet vi. and save it with a .XLS extention, use tab (default) as the delimiter
