03-05-2016 11:37 PM - edited 03-05-2016 11:45 PM
I am implementing one software to operate meter, in this I have to save data into the memory card before writing data on memory card(Removable) , I want to check if memory card is present in the device or not ? I am very new in LabView please help. best if post data diagram. Thank you in advance.
03-06-2016 12:40 AM
use these vis to see if there is such path in your system or not
htey are in file I/o branch
03-06-2016 11:30 PM
Hey,
Are you using a cRIO ? Anyways, you could try looking at this example to get an idea on how to go about this. This example is based on the previous users message.
https://decibel.ni.com/content/docs/DOC-5825
Suraj Pawar
AE, NI India
03-07-2016 11:45 PM - edited 03-07-2016 11:46 PM
Actually memory card is not in Computer it is in one device which I connected to system. Device is Energy measurment Meter,I want to check memory card is inserted in that device or not
03-08-2016 12:41 AM
03-08-2016 04:15 AM
kiwagh105@gmail.com wrote:Actually memory card is not in Computer it is in one device which I connected to system. Device is Energy measurment Meter,I want to check memory card is inserted in that device or not
The easiest way we found to do this with code running on RT targets was to attempt to write a file (e.g. a 1 byte binary file) to the device and see whether or not it was successful. I think there's also the 'get volume info' VI but I seem to remember something weird happening with it on RT targets...but it's been a long time since I tried it.
03-09-2016 11:31 PM
I am sorry but I don`t think you will be able to use LabVIEW File VIs to check for the presence of the memory card in an external device, if that device is not something LabVIEW can program. You can try exploring if your device supports a command set through Serial communication, TCP communication. If yes, then you could try sending those commands from LabVIEW.
Best of luck with your application !
Suraj Pawar
AE, NI India
