concatenate the data from 2 arrays into a third array just like in concatenate strings
Hi. as the title says, i would like to concatenate the data from 2 arrays into a third array similar to what concatenate strings does. All arrays should be 1D. For example, assume there's Array 1 with the folowing elements: 1;2;3;4. And Array 2 with: a;b;c;d. I would like array 3 to be 1a;2b;3c;4d. Now this could be done easily with above mentioned concatenate strings, and then build array. but Array 1 and 2 have something like 150 elements. Pretty tedious. Any ideas?
Message 1 of 10
(3,458 Views)
The interleave 1D arrays primitive from the array palette does just that.
Enjoy!
Epictetus
Antoine Chalons
Message 2 of 10
(3,454 Views)
Accepted by anarki
Take the two string arrays into a for loop, concatentate the strings inside the loop and run the result back out to array3.
Autoindexing handles the array manipulations.
MIke...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 10
(3,453 Views)
oops... ignore my post I missed half the comas in your wish for the 3rd array, mikeporter is right, a concatenate string inside a for loop will do it.
Epictetus
Antoine Chalons
Message 4 of 10
(3,447 Views)
that seems to do the trick. thanks
Message 5 of 10
(3,435 Views)
Autoindexing is a very powerful capability. In addition, if the arrays are potentially large or the string of varying length, you might also want to look into "Iteration Parallelism".
Mike...
LabVIEW Champion
Message 6 of 10
(3,424 Views)
What if your program is very time sensitive (due to hardware) and you've got a ton of data? Isn't there another possible way to merge two arrays into 1 without looping? All I'm really trying to do here is pad (string formatted) data with zeros.
Thanks, in advance!
Message 7 of 10
(3,234 Views)
Please, disregard for now. I went further back in my program and think that I may be able to change the formatting when the data is retrieved: %06x
Message 8 of 10
(3,229 Views)
Whayt makes you think that "looping" impacts performance?
Show us exactly what you have and what you want and we will be able to suggest alternatives.
Message 9 of 10
(3,208 Views)
Thank you for your offering, altenbach, but I realized a better solution for me was to change the formatting and pad with zeros. In my case, the "looping" would have occured during FPGA data transmitting/receiving and I'm already strectched for time.
Message 10 of 10
(3,196 Views)
