01-05-2015 05:01 PM
I have installed a new cRIO9081 system and can see it as a remote system. However, when I add a Ni-9214 module, it does not see the module, even after I refresh and restart the cRIO. On the old system (cDAQ-9188, this worked.) Is the cRIO not a plug and play type of system?
01-05-2015 08:41 PM
Where are you trying to see it? The cDAQ comment makes me think you're looking in MAX. You won't see any modules there for a cRIO.
Create a project and add the FPGA Target. You'll find modules under that tree.
01-06-2015 09:41 AM
create a project in Labview? I'm sorry to ask questions like this but I've never used DAQ or cRIO systems like this before.
01-06-2015 11:49 AM
Have you taken a look at our Getting Started with CompactRIO and LabVIEW guide? It walks you through setting up the cRIO and the modules in a LabVIEW project. Take a look here: http://www.ni.com/pdf/manuals/372596a.pdf
