02-04-2016 11:42 AM
hi,
i continusally ever 1sec ones read data from data base table.may i know about after long time it will creat any memmory issue or memory leakage but now it working no error.
02-04-2016 12:01 PM
Why do you think there would be a memory leak? I think the more likely scenario is that you get complaints from your IT department for querying data every second.
02-05-2016 03:21 AM
k but i sreach web some body post timeout error accored after long time data continually read. that why i am asking.
02-08-2016 08:32 AM
That's why you are asking what? If the code you are running, which isn't currently producing any error, will produce an error? Is that your question?
I think the decision you have made to query the max value of a column every second is not a wise decision but if it works and you are satisfied with its operation, then go with it.
