convert Ettus USRP X310 into NI 294x/295x
Hi all,
i'm trying to convert X310 of Ettus which is Used at Ubunutu with GNU Radio
based on manual at this link
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YKeECAW&l=ko-KR
I followed every single element but after doing all step
i powered up device and connect the deivce via 1G ethernet cable and UTP port at mainboard ping the device at cmd but 192.168.10.2 dosen't respond and still respond at 192.168.30.2
but it's not appeared at NI-configuraion utility
so i should connected at  Ubuntu and upload fpga again
and then connected to PC with Window Labveiw then it appears again but still same message appear (update needed)
so i try to find solution by myself
i found this page
https://forums.ni.com/t5/LabVIEW/connecting-Labview-with-X310/m-p/3907265#M1109063
solution was update the fpga
but how?
Message 1 of 1
(128 Views)
