counter reset to zero
hello,
How can I do that, wenn the case struct is true, the counter have to reset to zero, (  a == 0)  and  counts again.. I attached photo for my vi..
BR
(2,785 Views)
Accepted by nichts
Use a shift register in your outer loop.  You also might want to double check your code.  You may be doing some simple things in a complicated way.  The x+y doesn't make sense to me.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,771 Views)
you have it backwards....
Spoiler
(2,762 Views)
