doubt on data convertions
One way to do it:
Message 11 of 29
(1,010 Views)
@TerraNova wrote:
Look into "String/Number Conversion" palette.
Attach ouput of "VISA Read.vi" with last character deleted ("*") to the "Number To Fractional/Exponential/Engineering string.vi" (one of these three - parameters depend upon protocol).
That's all You need, If I cought You right.
Smiley Very Happy Ah, yes, my fault.Smiley Very Happy
Darin goes right, by the by.
Message 12 of 29
(997 Views)
can you post the vi in labview8.5 version. So, that i can see the code with help option.
Message 13 of 29
(990 Views)
I just copied your VI but its not giving output as 3.3v ...can you help me where is the problem.
Message 14 of 29
(973 Views)
Right-click the lower Boolean Array to Number and select 'Sign Extension Mode' and choose Always.
Message 15 of 29
(970 Views)
There is no such kind of operation. I see only unsigned, signed(8,16,32,64) and FXP.
Message 16 of 29
(966 Views)
I see it.
Message 17 of 29
(958 Views)
OMG, Its rellay not visible in my labview 8.5. Can you see down picture or am i doing any mistake. Thank you for helping hand.
Message 18 of 29
(950 Views)
I do not have LV8.5 installed anywhere, but I know that was not available in LV8.2 and available in LV8.6.  It was not listed as new in LV8.6 either.  Plus, save for previous does not complain when I save for LV8.5 but does strip the output configuration in LV8.2.
At any rate, try this version saved for 8.5.  If the configuration is lost then the workaround is simple.
Message 19 of 29
(938 Views)
The given VI is also not resulting 3.3. So, how I can go ahead with this kind of problem. I have labview9 version in my univ or is it possible to work in 8.5 version.
Message 20 of 29
(932 Views)
