function of attribute node "palette type - grayscale"
i wanted to ask you, what the function of this attribute node "palette type" (grayscale) is?
It is included in (almost) every VI, created in Vision Assistant.
Message 1 of 9
(3,015 Views)
Please crop your embedded image next time. There is no need to include 1M white pixels!
How old is your LabVIEW version? I think it was in the last century when property nodes were still called attribute nodes.
What happens if you right-click the node and select "help for palette type" or similar?
Message 2 of 9
(3,006 Views)
The function is the mapping of pixel value to "color" on the Imaq display.  Gray scale will map your 8-bit image to 256 shades of gray, and RGB or HSL to colors.  Other settings are binary, temperature or gradiant which use a different color to value mapping.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 3 of 9
(2,999 Views)
So, it doesnt change image information? Is it only a setting how (in which colors) to display the image information in the frontpanel?
When I process an rgb image in an VI, this node has no impacts on the processing?
Message 4 of 9
(2,994 Views)
It's a property of the indicator. It cannot change the incoming Data.
Message 5 of 9
(2,991 Views)
I dont see any difference in an displayed rgb image, when I change from grayscale to rainbow or something else. And I see also no difference in displaying when I erase the node..
So I dont understand this.
Sorry for the big image.
Message 6 of 9
(2,990 Views)
thanks a lot!
Also for correcting me.
Message 7 of 9
(2,989 Views)
I would think it only applies to palettes images. If you have an RGB image, palette settings have no meaning.
Message 8 of 9
(2,986 Views)
Yes palettes only are really useful for 8bit (or 16bit I guess) scaling in imaq displays.  Color images are already color mapped to RGB
Paul Falkenstein
Message 9 of 9
(2,979 Views)
