how can i make analog signal from abinary file ?
i wan to convert a binary file to signal to send it through usrp
Message 1 of 8
(354 Views)
Your question makes very little sense. The term "binary file" is very vague, because everything in a computer is binary at the lowest level. You also don't define what you mean by "signal".
Typically the USRP radio will convert your digital data to an RF signal. Maybe your want to ask in the USRP forum instead.
Message 2 of 8
(322 Views)
Let's get some more information about your file and how the data is stored.
Most likely you are referring to a file saved on a computer.  This would, of course, consist of 1's and 0's.
What is the file extension?  What process was used to save the data to file?
The USRP is going to expect data as an array of either; CXD (complex Double) or Integer as interleaved IQ Data.
There is not enough information provided so, even my magic 8-Ball says "Outcome uncertain, ask again "
"Should be" isn't "Is" -Jay
Message 3 of 8
(313 Views)
i just want to send a file that is saved in computer as a.txt file through labview for usrp how can i do that ?
Message 4 of 8
(285 Views)
What hardware and toolkits do you have?
What step is a problem for you (reading the file with LabVIEW? Sending the file data? Receiving the data on the other end?, Saving the received data to a file? etc.)
Message 5 of 8
(282 Views)
i want to know how labview read the file and how can i send it through the ni usrp code ?
Message 6 of 8
(279 Views)
LabVIEW is just a programming language. If you don't know LabVIEW programming at all, I recommend to start with the learning resources listed at the top of the forum.
(You still have not said what USRP hardware and drivers you have. For anything USRP specific, I recommend the already mentioned other forum)
Message 7 of 8
(276 Views)
Ettus USRP X410 this SDR //and the toolkits is the ni-usrp
Message 8 of 8
(267 Views)
