how to read and display a signal from my a miccrontroller (MCB1700) onto labview connected via a CAN port on a PXI machine
How do you read and display a signal from my a miccrontroller (MCB1700) onto labview connected via a CAN port on a PXI machine?
I tried using a DAQ Assistant but the CAN port is not included as one of the supported physical channels even though all its drivers are upto date.
Please help..
Thanks.
Message 1 of 24
(3,507 Views)
Which CAN Device are you using?
If you're using an NI-CAN device, go to MAX and select the Channel and launch the Bus Monitor.
Same procedure if you're using an NI-XNET device.
If you're using a third party CAN device, you'll have to use their software and API to monitor the CAN port.
Message 2 of 24
(3,500 Views)
NI-Can device (NI PXI-8461) is indicated that it is working properly on Max but my problem is, I don't know what option to use when making the block diagram in order for me to see my signal from my microcontroller (MCB 1700).
Please help..
Message 3 of 24
(3,497 Views)
Accepted by fhaljauf
If you can read it in MAX, then you should be able to run with the NI CAN Example.
Help->Find Examples
Search for CAN and look at CAN Receive.vi.
Basically, Configure the Network, Open the Object, Read in a Loop, Close Object when done.
If you have questions about the example, go ahead and post your vi and we can work from there.
Message 4 of 24
(3,492 Views)
Below is the error mesage that i get when i try to run the CAN Receive
Error -1074388957 occurred at NI-CAN Configure Network Interface Object (ncConfigCANNet.vi)
NI-CAN:  (Hex 0xBFF62023) The Interface is invalid or unknown.  Solution: Verify that the interface is assigned to a specific port within the Devices and Interfaces branch of  the Measurement and Automation Explorer (MAX).
What do you think is the problem?
Message 5 of 24
(3,488 Views)
How does your interface show up in MAX?
For my system, my NI-CAN device is CAN0.  Is that what you're using?
Message 6 of 24
(3,484 Views)
Attached herewith is a print screen of what is showing on MAX
The CAN ports are on NI PXI-8461
Hopefully that clarrifies something.
Message 7 of 24
(3,482 Views)
Message 8 of 24
(3,481 Views)
Odd.  I didn't realize that you were running through a remote PXI chassis.
I don't think this should really affect things though.
Here's how my device shows up in MAX:
What version of NI-CAN are you running?
Message 9 of 24
(3,473 Views)
NI-CAN 2.6.1 (2.6.1f0)
Message 10 of 24
(3,471 Views)
