how to take specific values from a 2d array
hi all
i have a 10X10 2d array of reasult. for instance:
1    2    3    4
5    6    7    8
9  10   11  12
and i want a specific values from the array/ say 1,3,7 and 10 (there is no given pattern to work with..)
I used the IndexArray but because it's about 20 values, it's hell to change and hell to debug...
Is there any more elegant way to do this?
thanx!
(this is one great forum, it's my first time posting a question but i've been following you for a while!)
(2,913 Views)
Assuming you know the values you are looking for, index the 2d array using a for loop and search for the specific value/s using search 1D array node.
I've to add that your question is a bit vague and may be barking up the wrong tree! It would help a great deal if you posted a snippet/vi of your current implementation.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,904 Views)
thanx for replying!
i currently have problem with the network on my labview computer so i cant upload pics or so..
i'll further explain:
the 2d array is a result of set of tests from which i want to take the results that are important for me.
i dont know the values for each test but the locations are constant.
the problem is that the IndexArray is too hard to read or change because of the quantity of the tests
 thanx!
(2,896 Views)
OK, so if I understand this currectly, you have a 2D array with 100 elements and you want to pick out 20 values whose index locations are constant.
"take the result" is a poorly defined description. What are the exact indices you want? Is there a regular pattern?
How do you want the output?
  • One at a time in a specific order?
  • As a 1D array in a specific order?
  • as a 2D array with all other elements zeroed?
I don't understand. What are you "reading"? What is a "test"? Why is it "hard"?
(2,891 Views)
Accepted by sebastiant
You can drag the index array function down, creating something that looks like this:
That will allow you to output multiple elements from the same array simultaneously, by putting in each separate set of indices. If you want to make it easier to debug, make the indices inputs, name them effectively, and group them in x,y pairs.
You could also make a boolean array and use that to select the indices you want. This makes more sense if your indices need to be selected graphically.
Colden
(2,866 Views)
wow!
colden R im in debt for you for all eternity!!
the second solution is great and exactly what i needed!
thank you very much!
(2,853 Views)
