network copy of labview
Is there a way to have a copy of Labview on a network?
I will be developing Labview applications on a variety of computers. Once the programming is finished, I will use Application Builder to make it executable.
Thanks in advance.
Bill
(2,183 Views)
Hi Bill,
there are two things:
The license agreement:
Floating, concurrent, or shared use is not permitted under this Agreement (i.e., allocating an individual license or one seat of a volume license to non-simultaneous use of the SOFTWARE (in whole or part) on multiple machines).
You are not allowed to install it on the network and use it from several computers.
The technical:
If you would map always the same drive letter it will work. You need to copy some registry entries from machine to machine to work properly. You need to differentiate the registry after installation and before installation and copy that to the other machines. I don't have any experience with it because we have enough licenses.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,160 Views)
