omega flowmeter sensor daq connection
Ok, i created it now.What should i do?
Message 11 of 15
(1,188 Views)
Now you can wire your sensor in the same way as MAX shows you.
Then you can test your sensor using MAX.
Then you can create your VI using this DAQmx task or by calling the appropriate DAQmx functions…
Message 12 of 15
(1,184 Views)
But where does it say how the connection will be?
Message 13 of 15
(1,175 Views)
Accepted by sgirgin
It shows it in the task configuration dialogue…
Message 14 of 15
(1,172 Views)
ahh i see now thank you
Message 15 of 15
(1,169 Views)
