phase diffrence measurement
thank u so much...will implement and will come back to u after performing both techniques.....
Message 11 of 14
(1,030 Views)
The problem is same I am having a varrying phase difference as well as power factor. I have tried both VIs. I have made the following changes in the vi attached.
Message 12 of 14
(1,011 Views)
What is error observed? What is your accuracy expectation?
You are acquiring the signals using DAQ Assistance that too using finite samples. Using finite sample along with DAQ Assistant may cause a frequency leak at the starting and ending of time window.
Please create an analog continuous measurement task and read the samples in a while loop and process it.
You can use the “Voltage - Continuous Input.vi” example VI from LabVIEW
Message 13 of 14
(1,006 Views)
I got the solution. Its working fine. ALHAMDULILLAH. Thanks for your support.
I am attaching the working VI.
May ALLAH bless you.
Message 14 of 14
(997 Views)
