property node
I have a question about the property node. The class is light blue and what does it mean? My Labview is 2010 and I can't find open VI object scripting. Do I need add-ons?
Thank you!
light blue color
noopenVIobject
no open vi object
Message 1 of 18
(5,515 Views)
Accepted by ivymerci
Light blue on properties and methods means that it is a LabVIEW scripting property that is not normally exposed.  In LabVIEW 2010 and later, you can turn these nodes on by an option in the Tools>>Options>>VI Server dialog.  You do not need another add-in.
Note that VIs which contain scripting properties will continue to show them, even if the LabVIEW they are being viewed in does not have the feature turned on.
Message 2 of 18
(5,510 Views)
Thank you DFGray.
I am new to Labview. I have turned it on(figure 1). Now I can find the light blue property. But I still can't find the Open VI Object(figure 2). Could you please help me with that?
figure1figure2
Message 3 of 18
(5,501 Views)
I get it. Thank you!
Smiley Happy
Message 4 of 18
(5,497 Views)
Open VI object is inside the LV Scripting Subpalette at the bottom of your figure 2.
Message 5 of 18
(5,496 Views)
There are also tan and red property nodes (see attachment).
I don't know what tan means, but red means the use of that property is deprecated.
Message 6 of 18
(5,468 Views)
Actually, I would call those yellow property nodes.
Yellow is the color for normal property nodes.
Message 7 of 18
(5,459 Views)
Yes,  I am aware that yellow is the color for normal property nodes.
I also know the difference between yellow and tan.
Message 8 of 18
(5,451 Views)
Brown is for properties which are marked as private.
___________________
Try to take over the world!
Message 9 of 18
(5,443 Views)
I had never seen the brown nodes before.
In the VI you posted, it only showed blue, yellow, and red when I opened it on my PC.  That's why I thought you were calling the yellow nodes tan.  I don't know why the nodes have a different color on mine.
Message 10 of 18
(5,436 Views)
