"Remove and Rewire" feature/bug?
@Darren wrote:
As you read on in the thread, you can see that Hooovahh thinks my setup is "silly", but it works really, really well for me. 🙂
Never going to let that one go hu?  I think I just had a change of opinion so quickly, that was just the word that came to mind.  I was semi-jelous of your many monitor setup and thought it would be something I would want.  Then after reading how you use them I quickly realized that isn't what I would want at all.
And I hope you know I wasn't saying your setup was silly, but that having a monitor for each window was silly.
A SSD for my laptop would be nice, I had one a while ago but it was too small.  There was a thread on LAVA recently where one user complained about how NI stuff was taking up 120GB not including files found under Program Files.
Message 91 of 120
(1,748 Views)
@Darren wrote:
Remove Structure - If you select one or more multi-frame structures and press Ctrl-Space-Ctrl-Shift-R, the "Remove Structure" operation is performed. I've been using this one *a lot* since upgrading to LabVIEW 2014...anything I can do to avoid navigating right-click menus for common editor operations!
Any chance that in 2015 we can get this to perform what the old "Remove Structure" did, that is WARN THE USER IF THERE ARE HIDDEN CASES WITH STUFF IN THEM?
Message 92 of 120
(1,735 Views)
Nope.
But feel free to add your own scripting code to the QD plugin to present a warning dialog for yourself. Here's where the plugin lives:
resource\dialog\QuickDrop\plugins\Remove and Rewire.vi
Message 93 of 120
(1,724 Views)
Or ctrl+z and blush.  😉
Bill
CLD
(Mid-Level minion.)
Message 94 of 120
(1,713 Views)
Usually, when you realize that you deleted a bunch of cases you did not realize were still there, it is too late for Ctrl-Z. And you won't just blush...
Message 95 of 120
(1,706 Views)
I can't recall the last time I deleted a structure and didn't want all of it gone.  I've deleted a structure and wanted NONE of it gone quite often, though.  😉
Bill
CLD
(Mid-Level minion.)
Message 96 of 120
(1,696 Views)
Another thing to keep in mind, when you select a structure and press Ctrl-Space-Ctrl-R, it will perform a standard Remove and Rewire operation...the structure will be removed completely (including contained code), and pass-through wires will be preserved.
Message 97 of 120
(1,694 Views)
Here is another case study.
I wanted to replace a VI's inputs (references to controls) by value inputs instead:
Do the magic and you get:
Duh.
I know the broken wire is connected to a reference input, but couldn't we do better?
EDIT:
Hmm... If I select the reference wire connecting the PN to the close reference, that works...:
Message 98 of 120
(1,598 Views)
This issue looks to be fixed in LabVIEW 2015.
Message 99 of 120
(1,586 Views)
Similar (so hopefully fixed in 2015?):
I replaced a DVR by the actual data type in a subVI:
If I select the Delete DVR and Ctrl-Space-Ctrl-R it:
while of course I was hoping for:
Message 100 of 120
(1,547 Views)
