"Remove and Rewire" feature/bug?
Replacing the "Negate" primitive:
by a Compound Arithmetic gives this:
whereas I would prefer this:
Message 71 of 120
(1,351 Views)
Why would you need that?  If you are replacing one function with another, it is because you want to do something different.  If it is just to get a functionally equivalent piece of code, there is no reason to ever to the replacement to begin with.
Message 72 of 120
(1,339 Views)
@X. wrote:
Replacing the "Negate" primitive...
Makes sense to me. I filed CAR 495471 on this. Should be fixed in LabVIEW 2015.
Message 73 of 120
(1,340 Views)
One use case off the top of my head...you want to add something to a negated value, but don't want to add another function taking up space on your diagram. Quick Drop Replace the Negate with a Compound Arithmetic, then grow it down and wire the thing you want to add.
Message 74 of 120
(1,334 Views)
Maybe a new one for your consideration.
I have (re)discovered that a Boolean can be connected to a Format to String node when the expected input is a string, resulting in a "TRUE" or "FALSE" string.
Therefore, whenever I have a chance, I clean up old code of the form:
The problem is, when I CSCR the Select node, I get this:
whereas I obviously want that:
Message 75 of 120
(1,299 Views)
Obviously you want the second thing?  That makes no sense.
You go from wiring a string into a Format into String, where the format string itself is looking for a %s.  And you think the replacement should suddenly be a boolean going in?
Message 76 of 120
(1,294 Views)
I am not saying it is natural. Just that this is what I was hoping for.
Message 77 of 120
(1,292 Views)
If it isn't natural, it's not exactly fair to call it obvious.
Message 78 of 120
(1,275 Views)
It'd be hard to set up rules for that function. As it works, it'll match the current string input of the Format to the left objects, matching a string constant. Prioritizing controls and also considering dynamic input possibilities sound very advanced.
In this case it'd be easier to just delete the Select and wire Condition instead of using the Quick Remove.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 79 of 120
(1,260 Views)
QD cleans up the constants for you.
I ended up deleting the node and manually removing the constants.
Message 80 of 120
(1,239 Views)
