scaling within subpanel
I have a subpanel and would like the vi inside the subpanel scaled to the subpanel plane is that possiable?
(2,839 Views)
Accepted by Just_me1
Have you tried Vi properties--> window size--> Scale all object on front panel as the window resize.
Or "This vi" node--> panel proeprties.
(2,828 Views)
Thanks...
(2,808 Views)
However, it scaled all my objects but kept the fonts to my indicators the same
(2,791 Views)
Check this one: Panel resize event
Also you can try using "This Vi" property node.
LabVIEW Scalable Tabs to Control Separate Tasks on the Same Interface
(2,788 Views)
