select from string?
i have string like #456,123 and want to select (4)[as the second digit not more] to add it with other no.
what shall i do?
(2,618 Views)
This is an extremely basic task for LabVIEW.
Have you even gone through the tutorials????
http://www.ni.com/academic/students/learnlabview/
(2,616 Views)
how i can do it
Spoiler
(2,610 Views)
Accepted by oiuuhjoi
Do what? What do you mean by "add it with the other no"? Do you mean you want to mathematically add the 4 and the 5 to get 9 or perform string concatenation to get '45'? Do you want to add the 4 and the 56,123?
To select a subset of a string you can use the String Subset function. There is a zero based index input and a length. Index 0 would be the # and index 1 is the 4. There is also a length input which defaults to the rest of the string. Wire a 1 to that.
LabVIEW 2012
(2,602 Views)
You a regular expression. The expression "#(\d)" would isolate the first digit after the pound sign.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,598 Views)
