show continuously accumulating waveform chart
I read around 1000 points per iteration that I would like to show on a waveform chart. If I just connect a numeric array to the Waveform Chart, it shows a smooth sin wave and it looks like it is just appending new data to the old one (kind of like a queue).
However, if I use a waveform, it overwrites the previous data with the new one. I want to see 2 seconds of data at any given time, so just showing 1000 points on a corner does not help.
I have tried appending to a waveform using shift register and it does show the result I want, but overtime the size of the waveform gets very large and it slows down the system. I could implement some size-checking and stuff, but is there
an easier way to make the waveform input behave a numeric array input?
I need to use waveforms because I want to stack multiple plots an it gives an "Out of memory" array if I use a 2D array.
(4,170 Views)
Accepted by abdel2
Got it working. Had to modify the timestamp in each iteration.
(4,147 Views)
I am vasu. I want to add cursors to wave chart. i can add cursors to wave graph. but i don't know how to add cursors to wave chart. plz send me that program to my mail(srinivas.perala@yahoo.com)
(3,859 Views)
There is no way to add cursors to a chart. You will have to use a graph. If you need the ability to plot a point as it is acquired, you can use a shift register with a build array. Since this could lead to performance issues if the array grows with no bounds, you might want to incorporate a buffer like the chart does. There's an example called XY Chart that uses one.
p.s. NOT a good idea to post your email in a public forum. All you will get is spam. All questions are answered here and not by email.
Message Edited by Dennis Knutson on 02-24-2010 09:12 PM
(3,857 Views)
   Thank you. can you attach the program.
(3,823 Views)
Why don't you go to LabVIEW, click on Help and then Find Examples?
(3,817 Views)
No need to attach. I got the results. Thank you
(3,810 Views)
